- 25 Sep 2003
- Manchester
All I've done so far is stick the CPU to 42 and manually set the ram voltage to 1.5v. The computer works great but I'd like to see if I can get more from it. I'm prioritising power usage over outright speeds so I don't want to set my CPU voltage manually as then it will always be running higher than it needs until I push the system.
Is there a way to get to around 4.5Ghz but keep the automatic setting of volts on the CPU and other system components?
Also, what's the XMP profile I keep hearing about with the RAM side of things? My ram is set manually to 1600Mhz and auto timings at the moment.
