overclocking past 3.85ghz
17 Oct 2012
Norf FC Yorkshire
I'm trying to get my sempron 145 past 3.85ghz but i am finding it really hard to get it stable past these frequencies and it keeps blue screening when i put it under load even at 3.875ghz. The tempratures are fine with the cpu hitting max temps of only 40C when under full load at 3.85Ghz. I currently have a gigabyte 970a ds3 which isn't the best board but i was hoping to get to 4ghz.
I have the following settings in the bios:
cpu multiplier X14 (3850mhz)
bus speed/cpu clock 275
northbridge multiplier X10 (2750mhz)
ht link multiplier X8 (2200mhz)
ram multiplier X4 (1100mhz)
cpu voltage 1.400v (1.350v is stock)
northbridge voltage 1.200v
ram voltage 1.520v
any suggestions :confused:
also if anyone has any advice on possibly unlocking the second core because i haven't tryed this yet but core temp os saying my cpu is regor instead of sargas, is that code name for athlon ii x2?
