Overclocking Pentium K CPU?
1 Dec 2014
Hi folks,
Haven't yet but thinking of purchasing Pentium K to go in a budget gaming rig, instead of an i5, and then overclocking it with this cooler http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-CM
Is this a good cooler? And is this a sensible idea? I was thinking the Pentium K would be a good placeholder to save money for now, replacing it with a higher-end i5 or i7 in a year or so. I've heard it's very overclockable and will still play modern games on decent settings. Hoping to be able to run FarCry 4 - think that will be doable?
Grateful for all thoughts!
Yes it is a good cooler.
Yes overclocking the CPU is a good idea.
Farcry 4 depends on other factors including your GFX card.
Overclock.net has tested that the G3258 bottlenecks a 970 / R9 290 pretty badly. That basically means that you're stuck with a lower-end GPU with that CPU. Farcry 4 is a very demanding game, so you you'd be stuck to low settings with that CPU on it, even if your GPU can do it.
Fair play, thanks for responses. Was thinking of getting the MSI GTX 750Ti, which I know is a lower end card anyway.
Whilst we're at it, will the Asus Z97-P mobo support overclocking? That's the one I'm thinking of getting currently.
All Z97 boards will overclock. The cheaper ones will typically have less options in the bios and less power phases (Z97-P only has 4 phase). All you really need to clock Haswell is vcore, multiplier, maybe vring and LLC. I wouldn't go for too cheap a board though if you are going to drop a i5/i7 in later.
If I was looking to buy a board now my money would be going on the Asus Pro-Gamer.
That looks like a nice board, can afford that given the savings on CPU. How do you find out about the overclocking capabilities of these boards?
If the PSU is old, then be wary that its not degraded over time and has all the connectors needed for the board and GFX card etc.
Not really, nothing wrong with still buying a decent GPU, as he said he will be moving to an i5/i7 at some point.
It doesn't really matter with Haswell cpu's. The cpu will run out of steam long before you run out of options in the bios.
Paired a 270x with my wifes pentium . I thought it wise going not putting anymore power in , CPU gets battered in BF4 most likely due to core / thread count on dx11, hopeing when get five mins to test mantle my choice of GPUs will be justified. Everything else I've tried runs great and get great frames
I took a similar route to what you're planning and paired my Pentium K with 2x 6950s in crossfire. It did bottleneck them a bit but still gave me perfectly playable frame rates if I wasn't too unrealistic with the game settings. If you are looking at 750ti level gpus then I'd have thought the Pentium will do fine. I got mine up to 4.6GHz in the end.
