I'm currently trying to OC My Phenom II X4 940 BE from it's stock 3.00GHz to around 3.80-4.00GHz.
I've already OC'ed it to 3.40Ghz by changing the multiplyer to x17 but have kept the voltage at stock of 1.35v. I'm getting idle temps of around 32-34 degrees and load temps of around 45 degrees with my H50. This is where I'm not too sure what to do. I don't know what to change my voltage to since I'm new to OCing my CPU and should I change the FSB and not the multiplyer at some point? (I only recently got my H50, I was getting around 50 degrees at idle with the stock cooler which put me off OCing).
Thanks.
Thanks.
