Overclocking Potential for my E6600
10 Jun 2006
Northumberland
Guys what you reckon my E6600 is capable of with stock HSF.
Have just finished building the rig in my sig, and to be honest getting used to the BIOS on the Asus P5W DH board.
when O'Cing the potential of each chip differs...
you and your mate could have identical components but he may be able to OC higher then you...thats how it works...
Ok , the stepping of each cpu may give you a good indication of what to expect however there are no certainites..
What is your stepping by the way?
Just bear in mind the conroe cpus like to be overclocked :) so with that in mind and loads of patience and tolerance whilst overclocking you will find out for sure..
Then you can compare with others who have the same cpu as you with a similar type of setup as you so you know whether you have a good overclocking chip or not so good one :)
good luck..
