I have about 3 guides bookmarked for overclocking, but reading some of them & others posts I get conflicting info, so I'm asking:
What bios settings should I change before I start to overclock, some say enable xmp, some say disable, some say enable power saving, some disable, etc.
Also someone posted realbench as a good quick test to get a rough idea if its stable or not, is this any good? rather get a quick idea if its stable, then dial it back when its unstable, than spend 8 hours checking every step.
Currently using:
Aida64 - stress test
Cpu-z - checking if overclocks applied
hwmonitor -temps
I also read somewhere that some ram speeds dont work well with overclocking, my bios defaults to xmp off which gives me 1333Mhz ram, is that ok while I find my cpu overclock?
Thanks.
Currently using:
hwmonitor -temps
Thanks.
