Overclocking problem on Asus Prime X370-Pro
7 Jan 2018
Hey!
I have OC problems with my Ryzen 5 1600 on Asus Prime X370-Pro for the last 4 bios versions (on the newest one, 3402, also). I set 3.8GHz, voltage on 1.38 and CPU LoadLine Calibration on Level 3. When i saved changes and left bios i runned OCCT. Voltages were jumping about 1.46V after only 20 seconds (on large data!). LoadLine Calibration on level 2 and lower Voltage didn't fix the problem, it still was about 0.1V more than I set.
Does anybody on this forum have that motherboard? Have you overclocked your CPU on the newer bios versions? What were your results?
PS Also on auto settings voltages are higher than they should be - about 1.3, 1.32V.
Do you have you VCORE set on static or manual? You want the 1.38 to be the max power it gets to. Should be some settings in the BIOS to see this.
So what was the problem with the bios 5 revisions ago that meant you need to try these 4??
Bios revisions are not an upgrade if your system is stable and working well on a certain bios no need to ever flash it.
