- 13 Sep 2009
Hi,
I recently tried to overclock my Q6600 to 3Ghz.
I have read around several forums and found that my motherboard is not very good at overclocks for Quad Cores. However I still thought that I would be able to reach 3Ghz.
I finally reached a stable-ish 3Ghz at the settings below:
CPU Multiplier: x9
Rated FSB: 1333.3
Memory: Unlinked
Memory: 800Mhz
VCore Voltage: 1.35V
CPU VDD Voltage: 1.45V
All other values set to Auto.
But I had several problems with this:
1st was that after about a day of these settings I had a blue screen with a halting message, so it was not completely stable.
2nd was that my CPU was getting a little too hot at low 60s under full load.
And 3rd was that I had read that higher CPU VDD values put a lot of stress on the CPU and I was unhappy with it being that high.
I was wondering if anyone had any advice on how to overclock this combination well?
Specs:
Q6600 G0 stepping
Arctic Cooling Freezer 7 Pro
ASUS P5N32-E SLI PLUS
2x 2GB 800Mhz OCZ DDR2 PC2-6400 Gold Edition
NVidia GeForce 8800GT
Thanks, Mark
CPU Multiplier: x9
Rated FSB: 1333.3
Memory: Unlinked
Memory: 800Mhz
Specs:
Q6600 G0 stepping
Thanks, Mark
