I have my pc overclocked to 4ghz which is great and running fine for several months. and I would like it at 4.5ghz or 5ghz or anything inbetween. the problem is when I try and overclock it more and then run prime95 blend test my pc locks up. so what settings do i need to change to make it work. I have the cpu voltage on 1.35v and cpu/nb voltage at 1.2v.
I have tried 4.1,4.2,4.3 and upping the voltage but no luck still not stable.
also how can I make my ram run at 1600mhz which it should do instead of the 1333mhz it is at.
if you need any more info let me know.
my specs are
asus M5A97PRo motherboard latest bios installed
QuietPC Noctua NH-U9B SE2 Dual Fan Quiet CPU Cooler
AMD FX-8120 Black Editon 8 Core 3.1GHz Socket AM3+ Zambezi 125W
Coolermaster 550W GX Series 80 plus SLI / CrossFire Power Supply
Corsair Vengeance LP Blue 16GB (4x4GB) DDR3 PC3-12800 1600MHz Dua
Palit 1024MB GDDR5 GeForce GTS 450 DSub / Dual DVI / HDMI PCI-E,
here are some pictures of my bios so you can tell me what to change please
my specs are
