you can run 9 * 400 to get 3.6ghz and then your memery will just run at stock speed assumming its 6400
Changing the Front Side Bus To Northbridge Strap will adjust your memery speeds... not used the board but if the BIOS follows the standard Asus layout then link in my sig for overclocking p35/x38 should be of some help
