- 1 Jun 2010
- Bedford
Hi guys
I have a Q6600 G0, 1.2625V VID. I was interested in overclocking the cpu to 3.0GHz from 2.4GHz (stock speed). I kept the Vcore to 1.2625V in bios (stock voltage). Here are my preliminary results with Prime 95 running for about 10-15mins.
Q6600@ 3.0Ghz
CPU-Z readings:
Idle 1.200V
Load 1.168V (Prime 95)
Idle 1.200V
Load 1.168V EIST Disabled
Idle 1.232V
Load 1.216V Load Line Calibration Enabled, EIST Disabled
Now looking at those figures EIST enabling/disabling doesn't seem to be making difference although I experience quite a high Vdrop/Vdroop compared to Bios setting.
However when I turn on the Load Line calibration(LLC) there is improvement in Vdroop and Vdrop.Also the multi seems to be fluctuating now between X6 and X9 even though C1E is enabled. It seems that LLC is somehow interfering with C1E.
I wanted to ask should I overclock my cpu with LLC enabled. Doesn't it seem more viable to use LLC with which hopefully I can get better overclock for the same voltage rather than upping the Vcore in Bios which would be like pushing more voltage through cpu and experiencing high Vdroop thus making my overclock more unstable (if you know what I mean)?
Many thanks
Q6600@ 3.0Ghz
CPU-Z readings:
Idle 1.200V
Idle 1.200V
Idle 1.232V
Many thanks
