So after overclocking my card, played warframe and at a random length of time in the mission, it says Display driver AMD has stopped responding and has recovered.
So I loaded up valley benchmark, just kept it running for quite some time and I got this warning as well.
I do know it is my overclock setting as I tested without OC and its fine, but don't know how to approach it. Should I decrease my core speed+decrease voltage or increase voltage and see if I don't get this problem?
I don't think its the gpu memory as I tested using valley benchmark at default memory settings, with the core speed+volts at Overclock.
Using a HIS iceQ boost 7950 OC at 1100/1500 with afterburner at 1.206mv. I flashed my bios so I'm using a no boost.
The weird thing is, during overclocking, there was no problem with valley benchmark, however just running valley for a random amount of time, without bench I have this problem. Probably I miss that while only relying on valley bench to OC.
