Hey, 2 questions.
1. I read that you can get the CPU voltage to not go above a certain number, but it will still allow it to drop below this limit in order to not overuse the CPU when the additional power isn't necessary. I tried doing this using the adaptive voltage setting but after lots of fiddling (using auto and manual voltage offsets and changing power plan to balanced) i still couldn't stop it going over the limit. Could someone explain how i could achieve this? The voltage i want as the limit is 1.18V.
2. I tried a couple of speeds and as my general knowledge of overclocking is low, I would like someone who knows more to tell if the values i'm getting are decent or not and if not how i could improve it if possible.
Processor: i7 6700k
Cooling: Cooler Master Hyper 212X
4.2 GHz - 1.18V stable - 69degC max using standard intel burn test - 61degC max using Cinebench
4.4 GHz - 1.25V stable - 78degC max using standard intel burn test - 62degC max using Cinebench
I didn't dare going any higher 'cause i thought those temps were kinda high :x
Thanks a lot!
Processor: i7 6700k
Thanks a lot!
