hi
i've recently upgraded to a qx6700 and have overclocked it from its stock 2.66 to 3.2 using the multiplier (from 10 to 12).. quite simple... I am using it for 3d rendering and wanted to see if i could get 1 quad core system to replace my 4 athlon 4400 x2 systems, and @ 3.2 it has done that which is quite impressive for the core architecture!
i was originally using an old zalman cns7700 for cpu cooling and under load (rendering with fprime3) it was hitting about 76 to 78 degrees (hottest core), the others tapered off 2 to 3 degrees... i needed to increase vcore to 1.35 to keep it stable for 24hours solid rendering.. i decided to upgrade the cooler to the noctua nh-u12f with dual 120mm fans.. after doing this i've knocked 20 odd degrees off the cpu temps... i can now run stable rendering using all cores indefinately with the stock voltage..
my question is this, it seems that regardless of how high i move the vcore (i haven't gone beyond 1.4v) i am unable to achieve a higher frequency than approx 3.2ghz (give or take a few mhz).. has anybody else experienced similar with overclocking? has my processor hit its theoretical ceiling as far as clock is concerned as it doesn't seem to be responding to vcore increases..?
spec:
intel qx6700 @ 3.2ghz
abit ab9 (bios 17)
4 gig corsair pc6400 ddr2 c5
vista 64bit
geforce 8600
coolermaster atc200 case (really vintage but very good).. 2 front 80mm fans running reduced speed, 1 rear 80mm exhaust fan running reduced speed, and 1 top 80mm fan exhausting at reduced speed..
psu corsair 500watt
both 120mm cpu fans using the reduced speed adapters supplied, the pc makes a very slight auditble noise when on, and thats from the gfx cards fan!
any help or people who have experienced similar welcome.
noise is an issue for me as i intend to build 3 or 4 of these machines for rendering.. i have an "airflow controlled" cupboard to put them in once i have the setup stable, which will reduce the temps a little further as the cupboard is fed air from below the floor boards in the house (very cold all year round) and exhausted out the ceiling.
cheers
ian
spec:
abit ab9 (bios 17)
vista 64bit
geforce 8600
psu corsair 500watt
cheers
ian
