Overclocking RAM
17 Feb 2009
Got a Ryzen 5 3600 and 2 X HyperX Fury 8GB overclocked at 3000mhz from the factory set at 2400mhz
Mobo is A320 MH
If I go further do I risk my PC overheating ?
RAM produces hardly any heat compared to CPU or GPU. The difference between stock and overclocked will be a few watts. The PC won't overheat, though it's worth making sure the RAM itself has reasonable airflow.
