Overclocking tools Prime and IBT are not the be-all and end-all of proving a system is stable, they are a quickfire route to stress testing only.
They produce 100% load which in normal usage never happens (note normal usage, browsing forums games etc)
They produce high temps with load , again with normal usage never happens.
Taken if you pass with low temps brilliant but, like my cpu and many others if the temps are high THIS DOES NOT MEAN YOUR SYSTEM IS UNSTABLE BECAUSE IT GETS HOT AT 100% STRESS LOAD.
Im sick of seeing posts of run prime for 6 hours IBT for an hour, just why, just because some systems will and some wont who cares.
For years before these stress tests it was done by trail and error, BSOD IS YOUR FRIEND OR ENEMY depends how you look at it.
Its simple no BSOD, no freezing up then i would call that a stable system however you use it.
Plz stop if its to hot , if it dont run xxx, i wouldnt, it will melt, its getting boreing
My system according to OCUK experts will melt in a day, but im still here, still play BF3 etc, system on at least 18 hours a day, has been for a month.
Hmm i must be missing something (must be most post high oc then throttle back for 24/7, we all do it we all want the best OC we can get. You have to go to the limit then decide if you like it there or not). Seen with with Ivy, try for 4.8ghz then run at 4.4ghz 24/7.
Over and out! Yes Bass is my friend.
No ONE answered my question either in a previous post ALL TEMP RELATED.
Why can a GPU run at a constant 95c but it madness for CPU to do the same according to the majority. Read post i would love to no why, plus with such small heat sinks compared to CPU custom monsters.
http://forums.overclockers.co.uk/showthread.php?t=18399428
Who would in ther right mind oc to the point where you get a BSOD every now and again, it is what it is..... Takes another good swig and waits!
