I bought an overclocked system about two years ago. The CPU is a Q6600 at 2.40Ghz which was overclocked to 3.2Ghz for me. I recently noticed that Windows reports it at 2.40Ghz. In BIOS under "oc guru" it's on factory default rather than user defined. I have a couple of questions:
1) what is the most likely reason for that happening?
2) assuming I only need to enter user defined settings in oc guru, what settings should I use to get back to 3.2Ghz?
Thanks in advance for any replies.
