Overclocking Ryzen 2600
Thats not what killed it, those are stock volts.
Up to 1.425v is with in the long tern safe limit, you should get 4.2Ghz at that.
well , its dead , and they were the custom settings. the 2700 i had wouldnt even be stable at 4.1 @ 1.45v ... combined with a crap board like but its dead now so cant verify it. it died under a stress test at those settings
Thats sad, RIP.
depends on the silicon lottery, i have mine running @4.15Ghz with 1.35v, it doesn't like to go any higher.
That score is correct for stock.
Is this paired with an 1080ti, if so tightening your ram sub timings can give a big boost in performance for games, up there with an 8700K.
I'm getting 1219 ? 3.7ghz
That's not right, its way down, even my 1600 scores about 1150 at stock.
EDIT 2600, for some reason i though 2700.... Derp :o
Its about right, maybe slightly down.
yeah 1080ti...basically swapped out the Z390 and 9900k and plooped in a MSI Carbon and 2600
Didn't even reinstall windows :p
