Hi,
I'm waiting for the 4GB GTX 670s to arrive in stock so I can get two for an SLI setup.
What would be the best way to overclock them? Is it better to test each card individually, work out the maximum stable overclock and set them both to the slowest ones limit, or is it better to overclock them while they're running together in SLI?
The other thing is that I've got an MSI Z68A-GD65-G3 which has 3 x PCI-E 1x slots. I can't use the top one because it's covered by my Noctua heatsink, the next one down will be covered by the top GTX 670's heatsink which leaves one between the two graphics cards when they're installed. I've got an Asus Xonar STX PCI-E card which looks as if it'll just about fit betwen the two 670s, (albeit without a lot of room). Is that going to be a bad idea? Will the heat generated by the two GTXs damage the sound card?
Thanks
Thanks
lol, well spotted!
