Hi,
I've got a Gigabyte board here running 800Mhz OCZ memory which says its voltage should be 2.1v. Well, in the BIOS, it says its 1.84v and I cant adjust it. Only way i've got the system stable and running is to set the mhz down to 667mhz.
Is there a utility I can use from within windows to push the voltage of the memory up to the correct amount?
Ta
Ta
