I recently bought a new setup (in sig).
The cpu has been running at 4.0Ghz @ 1.3v for the past 2 days. I have been browsing the net, installing apps, gaming etc. The usual things I would do day to day on the system and I have had no issues or problems.
I thought I would try Prime95, and 1 core failed after 2 mins the others ran fine until I stopped after about 6 mins. The temps (in CoreTemp) shot up hitting as high as 80C! On idle it sits around the 40C mark.
So, would you regard the system as unstable?
I am quite happy to leave it as it is, unless it ever crashed on me, that would be my indication that something isn't quite right. Is it 'safe' to leave it at the current settings?
Thanks.
Thanks.
(prime stable)
Is it a simple case of just changing it to 21 in the bios?
