Right to start off i have never done any overclocking before, I've read up on these forums and others but i'm still a bit confussed by the whole thing. I tried using the 'inbuilt AI overclock' options that are avaible with the striker but they didnt post at all. just made a loud noise and showing DETERROR or something along them lines. Main thing was i couldnt find the 'FSB' or somewhat the right one? in my BIOS is was something like;
FSB - Clock Mode (Auto, Linked or Unlinked)
FSB - Ratio (Auto, 1:1, 5:4, 3:2 or Sync)
FSB (QDR, Mhz) <- I changed that to 1333
FSB (DDR, Mhz)
Now i wasnt sure what to change, just winged it after reading a post on here i changed the top one to '1333' which actually worked now its running at 3Ghz, but unsure if this is correct? such as i didnt change the CPU multiplyer or anything else? Just need a point in the right direction really, bit lost XD
CPU is running at 34/36 idle with stock cooler and the 3GHz atm
FSB (DDR, Mhz)
