Overclocking System for BF2142
30 Nov 2005
London
Hi,
I'm not overwhelmed with knowledge in overclocking, so I ended up using the Ai utility that came with my ASUS board. Other programs seem to cope with it ok but when I try to play BF2142 I get this weird performance issue. Whenever I move my mouse the crosshair/view moves to where I want but then seems to return to a similar position. (It isn't a latency issue like elastic banding.)
Therefore making the game unplayable whilst overclocked. This occurs online and in single player mode. Has anybody else experienced this? Is it something to do with the Dual core CPU? My GPU is overclocked via the CCC, if this has any bearing on it.
Anybody any ideas?
Cheers
B
Sys Spec below
ASUS P5B Deluxe WiFi AP
Hiper 730 Watt Type M ATX v2.2
Intel Core 2 Duo 2.67mhz 1066 FSB
Powercolor x1950xtx 520mb
2x1gb Kingston HyperX 8500 DDR2 1066Mhz
74gb WD Raptor
Dell Ultrasharp 2407WFP 24"
Razer Copperhead Laser Mouse
yup it does that if the system overclock is not too its liking.
dont use the ai software do it via the bios.
as for you're card as long as u clock it manually you'll be ok dont ask the software to find the best overclock.
