First off the main components
Mobo: Asus prime z390-p
Cpu: I5 9600k
Cooler: Modified corsair h45
For a start I've modified my cooler. I put arctic thermal paste on it. I took the fan away and replaced it with 2 akasa vipers running in push pull so that cooler is running better than at stock specs.
I've overclocked the cpu. 5ghz @ 1.32v. I'm currently running prime to test it for stability. Prime has been running for 3 hours so far with no issues. I'm actually using it to post this while it runs.
The question I have is about the temps. For the past nearly 3 hours the temps are as follows. 83 degrees on one core, 78-80 degrees on all the rest. I'm using hwmonitor to monitor this.
Are those temps to high? Should I lower the clock a little bit?
Cpu: I5 9600k
