I have had the amazingly good Intel E6600 2.4ghz dual core processor in my rig now for about 3 years..
I upgraded at the time from an AMD FX55 SLI system... so I replaced my mainboard at the same time.
I have since changed the mainboard again... (a while ago).. to an Asus P5QL (with latest bios).
All the tips about overclocking the E6600 that I have found have been a little sparse as the processor is now quite old. The ones I have found however have said that it is possible to clock this to over 3ghz with adequate cooling.
Last week I got a Coolermaster 600 Gladiator case to accompany a Corsair H50-1 processor water cooling sealed system. The processor now runs at about 24 degrees C at idle and sits at around 33 degrees C under full load (playing Bad Company 2).
I have tried to clock the processor before but it was very unstable even with a slight boost in the voltage recommended to me. The machine locks up on boot.
I did get it working at 2.84ghz for about 10 minutes before the machine froze. All this was before I got the coolermaster case so the temperatures were between 38C at idle and 60C under load... which I didn't like.
Does anyone have an experience in overclocking the E6600 to around 3ghz and what temperatures the processor would be able to handle over extended periods. I did figure that with my new cooling I would be happy for it to run at 45C as that is not far above the old idle temp I used to get.
