Zephyr said:
Hi Concorde, as a silver surfer of 69
I needed all the help I could get and you certainly gave it m8. Trouble is to go further how do I go on. Z
Once you have tested enough, 48 hours at full load or something (I fold 24/7!) you can try and work on something else.
I would drop the CPU multi down one, and boot at 400FSB, download clockgen and set the PLL as CY28551.
Now, set NB voltage to 1.65V and SB to 1.6V. And start raising the FSB using the PLL Control panel.
Upping FSB in BIOS changes the strap so you loose performance.
Using this program, 10mhz at a time, start upping the FSB. Test using Windows memtest (google) and make sure it passes atleast 300%. YOu will need to use two instances of Windows memtest as each program only supports up to 1gb, so give each one 870 mb odd of ram to test.
Once you start getting errors try adjusting the memory voltage up and down, if that doesn't work back down 5mhz and try again. If this passes 500% then your set to raise the CPU multi again.
So reboot and up the CPU multi. Give the CPU 1.4V or add 0.050V more to what you had.
Once in windows do the same using clockgen, setting 10mhz at a time and test using Orthos, Using Small FFTs. If it errors up the CPU voltage up two notches and try again.
Watch the temps using CoreTemp, try and keep it under 60C, max voltage is 1.5/1.55 depending on temps.
CR.
