I've been trying loads of combinations, changing the bclck repeatedly... tried messing around with voltages and frequencies to underclock ram etc, but no luck...
I've had the machine at 3.6, 3.7, 3.8 ghz, with the temperature soaring to 90-95 according to real temp and core temp... which I don't really trust at this stage... The thermalright 120 I have is barely warm, pushing out reasonably warm air... Speedfan says Im at 70...
Since letting the motherboard take control of the fans (instead of the fan controller) its at 3.6ghz at 81,81,84,84 degrees...
I have read so many guides and tried a lot... What am I doing wrong? I have a thermalright 120, with push noctua fan (will try a pull as well at some point)...
3.6 is idle with 50 degrees... ambient is quite high as its been baking recently but its relatively cool right now and still getting such high temps...
Guessing the heatsink could be sat incorrectly? too much heat compound? I'm a noob and stuck!
All help would be greatly appreciated at this point!
