Hi there,
I recently started my first build (specs below) and i am in the process of attempting my first overclock.
As we speak the PC in question is Priming (blend) next to me and seems to be a fairly healthy 36c (25c idle) on both cores at 100% load 5 1/2 hrs into the test. Room temp is around 22c.
The problem i think i have is that when i change something in the BIOS ie lowering the strap or upping the FSB 20 MHz, when i save and exit the whole PC seems to shut down for a few seconds before bursting back into life and loading into Windows - this concerns me because if i boot into BIOS , have a look around, maybe even up the FSB 5MHz, after saving and exiting the PC doesn't perform the same 'hard' shut down as before but just reloads it's new settings without the whole motherboard shutting off - is this wrong, and if so why? I am wondering whether my voltages are set correctly, but don't mind admitting i know nothing about the subject.
Since i began this experiment i have run into another problem. When i shut the PC down i always switch off the PSU, as I'm sure most do, thing is when i boot the PC after this it will power on for a second (all lights and fans throughout the PC will ignite or spin up) but then shuts off for a few seconds before bursting into life (deja vu) and running as normal. If i shut down and leave the PSU switched on and then boot i don't suffer this, it just boots straight through too Windows. Anyone have any idea as to why this may be happening? Is it linked to the problem above?
Specs: Currently on the bench;
CPU: E8600 C2D - Vid 1.1750v - Q822A435
M/B: Asus Maximus Extreme Intel X38
Cooling: T/R True Black - 2* 'Antec 3' 120mm Fans Push/Pull - 1* 40x20mm fan zip tied between the heatpipes blowing on H/S. As5 paste.
RAM: 4GB (2*2) Corsair XMS3 DDR3 1333MHz 9-9-9-24/Dominator Fan. Slots A2/B2.
GPU: GeForce 285 GTX XLR8 - Stock.
PSU: Tagan Piperock 800w Modular
HDD: 2*WD Raptor 74GB
Sound: X-Fi Xtreme Gamer
Keyboard, Mouse, 22" Monitor, Fan Controller, 1*DVD-R/RW, Antec 1200, Ultimate 64 bit.
Below are my BIOS Settings and some testing/monitoring, i would appreciate it if anyone could point out where i am going wrong and give me a nudge in the right direction
Prime, Core Temp, Real Temp, CPU-Z
BIOS
BIOS
BIOS
BIOS
BIOS
BIOS
BIOS
BIOS
Thanks in advance for any replies and taking the time to read/look
BIOS
BIOS
BIOS
BIOS
BIOS
BIOS
BIOS
BIOS
