Overclocking will I notice?
7 Jul 2009
Wiltshire
Hi,
I'm due to order the components for my new PC over the coming weekend :)
I was going to by the i7 920 D0 Overclocked Bundle @ 4.0Ghz.
My questions are; What real benifit will I see or have over the 2.66Ghz stock, should I just buy the stock config and overclock it at a later date and save the money?
I notice that there are a few posts from people having problems with the i7 overclocked bundles, which is making me slightly nervous about buying the 4.0Ghz bundle.
Regards,
Andrew
Hi..I purchased the 4Ghz bundle a while back, and mine failed to overclock as it runs too hot, so I'm running it all @ stock. So far, it's been really quick, so I can't actually say that I think i'd notice the overclock.
Maybe if I had much higher spec graphic card (mine's 8800gtx) so the chip could push it harder I might notice.
I orderwd my "Ultima Warlord" from ocuk its a AMD Phenom II X4 955BE 3.2gig [email protected] and I have to run mine at stock speed cus there is no stable oc for the new bios. I have also changed the case from a Cooler master Elite 335 to a Cooler master HAF 932 full tower.
TBH im very happy with the stock speed
Thanks for all the replies and thoughts, mind made up, I'll just buy the 2.66Ghz and possibly OC it myself at a later date.
Thanks & Regards,
Andrew
Do it yourself, that's the where all the fun lies. Also where all the education really.
As to whether you should overclock it or not, up to you. It depends how hard you work your computer really, if 2.66ghz feels instant to you then leave it be.
Definitely buy the components and do it yourself. You'll save a lot of money over the overclocked bundle. If it's fast enough for you at stock you can just leave it, and if you want more performance you can read up on OCing it. Then you can get 50% extra performance at a later date and it won't cost you a penny!
As for whether you'll notice the OC - during general Windows usage, probably not. During games and other intensive apps, you probably will. My quad was 33% overclocked (2.4 to 3.2), and one day the OC reset itself. I didn't notice for a few days, but as soon as I started a game it was obvious.
Quote for truth. You'll feel much better about your overclocked system if you have tweaked it all up yourself. Plus, you'll be more able to diagnose it if an error comes up, and may learn to squeeze a bit more out of it over time :)
Isn't that the holy grain for us?!
