Overclocking Winny 3200+ DFI Ultra-D
23 Dec 2004
Can someone give me some pointers please I just can't seem to overclock this 3200+ on the DFI I managed quite easily on my old Asus A8V Deluxe.
Can I have all the bios settings I'd need to tweak divider, timings etc..
DFI Ultra-D - latest bios
1gb Corsair XMS XL
Winchester 3200+
update:
I've managed to get it stable @ 2.61 ghz
using the following settings:
290x9x3
133 mem divider so my memory is running @ 186mhz
Is there any way I can get it to 200 so its @ stock?
Cheers
Running 261 x 10 and using the 150 divider will get your memory to 196MHz.
You could try running on the 166 Divider and overclocking your memory a little, that'll increase your memory speed to 217.5MHz.
The corsair should be able to handle I would have thought. You may also see that your memory can run faster with a different bios.
There's a lot to choose from, and some have been set up for different types of RAM.
DFIstreet has tons of info on the various bioses, and they can all be downloaded from there as well. :)
thanks for ** help but ive solved it =D
got it running 290x3x9 = 2.61ghz
ram- 3-4-4-8 @ 474mhz which is good for xms xl
been running prime for 20mins and no problems
:D
