Overclocking with a 680i and e6600
29 Oct 2005
Newcastle upon Toon
Hey all,
I have an e6600, a Scythe Ninja Rev B, and a BFG 680i.
I want to overclock a bit and see what I can get out of it.
Can anyone tell me where the devil I should start - i'm a n00b at this. I've read the guides on here, but they aren't specific enough for me.
Cheers,
M
Cheers. :)
Can I ask what settings you have on your 680i to get that overclock? My multiplier is locked so i'm guessing its an FSB change + some voltage changes?
Ta,
M
for 3.6 my settings are, multiplier x9, cpu fsb 1600 with a cpu voltage of 1.525 set in bios, this is with my memory unlinked running at 800mhz with timings of 4,4,4,10, i wouldnt suggest leaping to this sort of oc straight of, try cpu voltage at 1.400 and raise the fsb to 1333, this will give a cpu clockspeed of 3ghz, test using orthos small FFT test for stability (8 hours is reccomended time) and monitor your temps with coretemp, i dont like to see mine go above 65'c. if the system passes 8 hours + you can raise the fsb more but then you may also have to raise the vcore if the system fails when running stress tests such as orthos
I have an e6600 and a 680i, Vcore is 1.375, 1.3V on the northbridge 3.2GHz (400x8), FSB at 1600 in sync with the ram at 800MHz.
Follow the sticky and it will all be okay.
