Overdrive in CCC
5 Nov 2010
Hertfordshire
Hello you 'orrible lot.
I want to enable overdrive in CCC so i can just wang the memory clock up a little. However, i can't see it in CCC, how does one activate it?
Why not use Afterburner you say? Because i just want to do a small change and dont want to use a separate application, also, Afterburner isn't showing the clocks of the card (8790m).
Thanks in advance.
Best simple overclocking utility then? I've only ever used MSI Afterburner (and ASUS's poor version of it).
Looks like have to disable ULPS to go any further. TRIXX option for this isn't working, anybody know the reg key?
Open regedit, search for enableulps change 1 to 0 and each keys
After you find one you must search next. Restart.
Sweet, i found 3 or 4 entries. Will reboot and see.
This will no doubt set the GPU clocks low even when the iGPU (Intel 4600) is being used, but that's not a problem.
Basically i just want to test the memory overclock as they're gimped slightly by default for some reason, then i'll want to extract the BIOS and set them as default and do away with these tools.
What options (if any) are there to extract the VBIOS to edit the default clocks?
I've tried RBE + winflash but to no avail.
