overdrive/inputlag ?
16 Aug 2011
I have a llyama monitor and it has a overdrive option +2,+1,0,-1-2, OFF, what what would be the best setting to minimize button delay/inputlag on the controller?
Thanks Chris
The overdrive settings won't affect input lag on the controller. They are for response times only. Push the setting too high and you will see overdrive artifacts like dark or light trails when you pan the camera on games. Go to this website http://www.testufo.com/#test=ghosting and change the background colour settings and test the overdrive settings on each colour. You want minimal smearing/no smearing of the UFO without heavy dark or light overdrive artifacts. If you compare settings -1 to +2 you will see what i mean. You need to test all background colours and bands of shade to fathom the best setting. Hope this helps you out.
