As per title my shiney new gfx card (as per sig) maxes out CCC overdrive when running auto oc which is kinda annoying in one sense but pretty good in another.
ATITOOL i hear you all scream, i have tried that too but system hangs at 620ish where as CCC goes all the way to 690. I think the gfx card now has some sort of 2d / 3d setup beacuse it runs at 500 / 600 till you press auto oc then it jumps to the normal speeds of 650 / 750 then does the auto oc thing. It has a tick box in overdrive that states something like "run overdrive clocks in 3d apps only" or words to that effect but i can't get it to untick this damn box as it's ghosted out all the time. I think if i could untick this box i might have more luck with ati tool.
I have tried the non ccc drivers and thats just the same with regards to atitool. Not sure what else to try.
Any ideas? As i would really like to see what this card can do.
Sorry if this has been posted before i had a quick look / search but couldn't find anything.
