Sorry realised my post is a tad long,please bear with me
Right, I'm just about to undergo quite a large upgrade, as I'm making the jump to PCI-e (finally
) I will effectively be building a new pc
My current PC :
Proposed new PC (* denotes component from old pc)
The PC is used in my living room for general pc use,gaming and HTPC purposes (It drives my 2nd display (projector) for movie/freeview watching at the weekends).
I've had the coolermaster case years (I think I originally paid £230 for it
) and it still looks great but its a bit full now and isn't cooling as well as I would like. As stated before I'm upgrading most components, so will be keeping the old case for the old pc.
So my case requirements come down to :
The two I've been pondering over are:
Thermaltake VA8000BWS Armour Super Tower
likes
Akasa Mirage 62
likes
Any opinions, are there other cases I'm missing?
Can any owners of the above two recommend them?
Cheers
) I will effectively be building a new pcMy current PC :
- Coolermaster ATC-201
- AMD A64 3400+ (socket 754
) - Gigabyte mobo (can't remember the model)
- 2Gb Corsair XMS3200
- Asus X800 XTPE
- X-Fi Fatal1ty FPS
- Nebula DigiTV freeview PCI card
- Zoom 5506 PCI ADSL Modem
- Pioneer 106S DVD-ROM drive
- Pioneer 108 DVD-R/RW drive
- Various hard drives (3xIDE,2xSATA)
- Enermax 430w PSU
- 4x80mm case fans (came with the case)
- Arctic Cooling ATI 4 (for the X800)
- Arctic Cooling Freezer 64 CPU Cooler
- Akasa sound dampening case mats
- Intel Core 2 DUO E6600
- Motherboard undecided yet
- 2Gb G.Skill DDR2 NR PC2-6400
- Sapphire Radeon X1900XT
- X-Fi Fatal1ty FPS *
- Nebula DigiTV freeview PCI card *
- Zoom 5506 PCI ADSL Modem *
- Pioneer 108 DVD-R/RW drive *
- Various hard drives (keeping the 2 SATAs from old pc maybe one IDE and adding another large SATA II)
- Enermax Liberty ELT620AWT 620w PSU
- Artic Cooling Accelero X2 Cooler (X1800/X1900 Series)
- will be replacing any case fans with Akasa Ambers
) and it still looks great but its a bit full now and isn't cooling as well as I would like. As stated before I'm upgrading most components, so will be keeping the old case for the old pc.So my case requirements come down to :
- great airflow/cooling (will probably be clocking the cpu/gpu at some point)
- quiet (especially important for HTPC needs)
- Good looks (must look at least as good as the old ATC-201
- space for multiple hard drives without restricting airflow
- thinking of going for a black case this time
likes
- front grille looks great for airflow/cooling, also allows for another 120mm fan
- roomy, plenty of space for hard drives
- black finish looks quite nice
- side window, not overly keen on these
- large front grille, while probably great for cooling, I suspect this would not help dampen sound
- Large/heavy , the pc isn't always in the living room so needs *some* portability
Akasa Mirage 62
likes
- looks a nice and unassuming black box
- meant to have great cooling
- enough HD bays
- It does have a slight 'old fileserver' look to it
Cheers
