- 10 Mar 2015
I hope some kind soul(s) can help me out as I’m in need of some advice for upgrade options. I’ve always built systems for myself friends and family but nothing recently – as a result I’m frankly just out of date and unable to determine how to achieve good value, bang-for-buck without any obvious bottleneck issues. Reliant on your help as I just don’t have the time to get up-to-speed researching it inside-out.
My requirements are hopefully quite simple, this upgrade is for my tired work-horse, so nothing very taxing although I need something that will handle VOIP as well as possible. I do a lot of multi-tasking with multiple browsers, browser tabs, MS Outlook, Word, Excel, Access, Skype, Skype MP3 call recorder etc. I use 2 monitors, a Philips 234E5QHAW (HDMI) and a 19” Dell (DVI / VGA) but I’d like to add the 27” version of the Philips within a year – possibly sooner – in place of or as well as the Dell. I currently have 4gb RAM which is regularly reporting usage warnings.
I have an adequate 600W PSU (alpha a power ATX-600L), DVDRW, SSD and running windows 7 Ultimate (retail not OEM so hopefully can retain this).
So far I’ve narrowed down some AMD based options as below:
AM3+ based…
Asus M5A97 EVO R2.0
http://www.overclockers.co.uk/showproduct.php?prodid=MB-502-AS&groupid=701&catid=1903
AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz http://www.overclockers.co.uk/showproduct.php?prodid=CP-338-AM&groupid=701&catid=1967
Kingston HyperX Fury Black 8GB (2x4GB) DDR3 PC3-14900C10 http://www.overclockers.co.uk/showproduct.php?prodid=MY-195-KS
GPU - £40 to £50? 2048MB / R7 240 maybe?
-Or-
FM2+ Based (with integrated graphics)
Asus A88XM-PLUS AMD A88X (Socket FM2+) http://www.overclockers.co.uk/showproduct.php?prodid=MB-595-AS&tool=3
CPU – Either:
• AMD A10 7700K Black
• AMD APU A10 6800K Black
• AMD A10 7800 Kaveri
I’d like to keep the cost to under £250 if possible. I’m clueless about:
• Which of the above would be the best option?
• Should I go for faster RAM?
• How would an equivalent Intel based option compare?
Any and all help, guidance, advice, direction you can provide would be very well received.
Many thanks in advance!
AM3+ based…
Asus M5A97 EVO R2.0
-Or-
CPU – Either:
