- 9 Dec 2008
Hi all,
Its been a while since i posted on here (long while) but i am after some advice.
I am looking at a two stage upgrade of my PC (assuming that is the best option).
At the moment:
I am currently running an intel Q8300 with 4GB 800mhz DDR2 plugged into my Asus PQ5-Pro (yea totally need an upgrade) topped off with my MSI TwinFrozr GTX 470. Its powered by a Corsair tx650w PSU and is connected to my Dell SP2309w (which may also need an upgrade).
I am not really playing anything too taxing on my PC, Heros of the storm, hearthstone and a few other bits and bobs. However i would like to start moving back to PC gaming from my PS4. Especially Project Cars as i am a little miffed i cant use my GT-pro wheel
The plan was to upgrade my Mobo, CPU and Ram with a view to changing the graphics card later in the year. I currently have around £450 to spend now and will probably look at something like a GTX 970 later on.
At the moment i have in mind an i7 Devils Canyon 4790 with the ASUS Maximus VII Ranger and then 8GB of Ram. My heart isn't set on this but i would prefer a red mobo simply because i want to keep my now 15 year old Thermaltake Xaser III case (with a view to modding it a little).
Is anyone able to provide any advice/suggestions on this upgrade. Although i don't have loads of cash to splash i do like to make sure what i get lasts a while so like to buy half decent specs.
Thanks for any help you can offer.
Kind Regards,
Alex.
At the moment:
Kind Regards,
Alex.
