- 26 Jan 2005
Hi there
I have an XFX 6600GT graphics card, which ive had for over a year.I didnt really notice any problems with the card until recently, when I start noticing quite bad graphics tearing and artifacts while playing World of Warcraft. I then downloaded NVTemp Logger and recorded the temp, and I noticed that under load, the GPU core temp is often reaching 90C! Tonight when I ran 3D Mark the temperature hit 100C!. I know the threshold is 127C or something like that, but the fact that Im getting artifacts is definately causing concern.
Here are a few points which might help some of you guys diagnose the problem.
- Idle temp of the card is around 50C
- The card is not overclocked.
- Im using the stock cooler. However, I have removed this, cleaned out the dust, removed the old thermal paste and then evenly applied some arctic silver. (Still no change)
- Airflow in the case is not a problem. My overclocked CPU is 32 at idle and never goes above 50 under load. The NVidia tools also reports the ambient temperature at 40C idle. I have 1 intake fan at the front, 2 at the side and 1 exhaust fan.
I know these past few days have been hot, but Im sure my card shouldnt be getting this hot. Any help would be much appreciated
Id be willing to buy a better cooler, but I'd still like to get to the root of the problem. Also I have a zalman northbridge heatsink, and I hear that some VGA coolers wont fit with this?
Thanks in advance
Id be willing to buy a better cooler, but I'd still like to get to the root of the problem. Also I have a zalman northbridge heatsink, and I hear that some VGA coolers wont fit with this?Thanks in advance
