My case has nice airflow, and this problem has only started recently (about 13 hours ago or so).
I have my BFG 7950GT overclocked as stated in sig, and it was pulling about 61 degrees in games (according to RivaTuner anyway). Seems a bit low to me but oh well, may have been anomalous.
Recently, if I play BF2142 on max settings, as has been perfectly fine before, my graphics card overheats (hits 77 degrees or so as highest spotted temperature), the screen will go blank, monitor says it's receiving no signal, and the sound will jutter. Only fixed with a reboot.
Even if I go to default clockspeeds, the problem still occurs. I've tried to set fans to 100% at all times, as noise isn't an issue. Even up from the stock 35% in performance 3d, I'm recieving no lower temperatures.
What could be causing this? I've given the fan on the GPU a good blow to clear dust, it all looks clean. I've tried everything I can think of so far, and nothing has helped. Any ideas?
