Hello there,
I've bought this https://www.overclockers.co.uk/ocuk...zen-3000-series-gaming-pc-fs-1dn-og.html#t=b2 spec recently with AMD Ryzen 3600 and Zotac 1660 Super sitting in Kolink Inspire K3 Micro ATX case and yesterday I've run into a problem where my monitors would turn off with a pop-up saying Plug in cables, but I still could hear sounds from the game I've played. I had to turn off the PC and turn in back on. I assumed (maybe wrong) that it has to do with overheating of components, so I check it and while playing games the temperature of CPU is rising to 81 degrees and GPU to 83 degrees to the point where the glass on the case is getting hot.
Now, when I was ordering this PC I didn't think of that the case would be without any fans. So I've did some research on the case (perhaps should have done it before ordering
) and there are 2 spots for fans. 1 in the rear for 92mm fan and 1 in the front for 120mm fan. Can you help me choose both of them or perhaps only 1 would be needed to keep the temperatures down.
Anyway, should I be worried of these temps for now?
Thanks for your time.
) and there are 2 spots for fans. 1 in the rear for 92mm fan and 1 in the front for 120mm fan. Can you help me choose both of them or perhaps only 1 would be needed to keep the temperatures down.Anyway, should I be worried of these temps for now?
