Hi all i did a post regarding a problem i had.. and i thought my computer was over heating.. well since i did that post i downloaded a program called SpeedFan 4.32 .. with abit of luck some of u may have used this program and will be able to tell me.. what the temps mean. The problem i was having was the computer would just restart itself and it could happen after 10mins or 3hrs.. but mostly when im playing games. ok ill post my specs and temps
Spec:
Asus M2N32 SLI Deluxe **WiFi Edition** Nforce 590 Socket AM2 SLI Motherboard
AMD Athlon(tm) 64 Processor 3500+, MMX, 3DNow, ~2.2GHz
1022MB RAM 667mhz
NVIDIA GeForce 7300 GT ddr2
WD 320 GB SATAII HD
Temps
SpeedFan 4.32
Temp1 - IT8712F - 32C
Temp2 - IT8712F - 45C (This goes over 50C then turns into a flame symbol)
Temp3 - IT8712F - 40C (This goes over 50C then turns into a flame symbol)
HD0 - HD0 - 40C
Temp1 - ACPI - 40C
Core - AMD K8 - 45C (This goes over 50C then turns into a flame symbol)
If u can help me with this i would be most greatful .. any good info on a case & fans ect.. for cooling would be nice
Thanks
Tab
Oh i hope this stuff makes sence..
Spec:
1022MB RAM 667mhz
WD 320 GB SATAII HD
Temps
SpeedFan 4.32
HD0 - HD0 - 40C
Temp1 - ACPI - 40C
Thanks
Tab
