I won a X1900XTX Toxic during the summer. I had initial problems but they were due to an Antec 450 Watt PSU simply not being powerful enough to juice the card. I then went out and bought a Enermax 620 Watt Liberty series power supply and all was well and everything worked the way it should.
Just today I noticed that for some reason whenever I enter a 3D application the computer locks up and gets a blank screen and needs to be restarted, the time it takes for it to do this varies on the intensity off the 3D application for instance FEAR and Company of Heroes locks up instantly while Counter Strike Source can be played for about 2 minutes. Instantly I assumed overheating as it would make sense. I pulled off the side of the case and under clocked the card using ATI Tool by about 10 % on both the core and memory. Unfortunately these steps have not resolved the issue and I can't play any games. Any advice would be much appreciated.
Rig Specification
AMD 3700+ 2.2 G Hz
Asus A8N SLi SE
Corsair 1 GB RAM PC 3200
250 GB Seagate Hard Drive
Creative X-Fi Music
HP DVD Rewriter
Antec Sonata II
Using the latest ATI drivers updated them after I had realized the problem.
PS: I can't find my temperature of the GPU. What utility should I use. I can't find it in ATI Tool. I'm downloading catalyst control now.
Rig Specification
AMD 3700+ 2.2 G Hz
Asus A8N SLi SE
Creative X-Fi Music
HP DVD Rewriter
Antec Sonata II
