Can anyone help me with this?
I build the following PC in October:
Abit Fatality F-I90HD Aicro ATX mobo
2GB Crucial 5300 dual channel kit
Intel Core 2 Duo E6420 2.13GHZ 1066FSB
Antec NSK 4480B Mini tower case
It's all been fine as far as I am aware until yesterday when for no apparent reason it started that warning beep that you get when you are overheating.
I shut down all the running programs which stopped the beeping and started Abit EQ which showed CPU temps in the high 70s and low 80s.
Restarted PC and before it booted to windows the warning beeps started again.
Current temp is 66 degrees C, that's with a few bits int he system tray (symantec PC anywhere and SQL server express being the most notable) and 1 instance of Firefox with 1 tab open.
When I open programs it shoots up very quickly into the 70s and then drops off again but once I get a few programs running and start working it sits in the high 70s and keeps going into the 80s.
Thing is the air coming out of the case feels quite cool, marginally cooler then the air around the outside of the case.
System temp is a steady 38 degrees and PWM 41 degrees.
Fans seem to be spinning OK and it's nice and clean inside the case.
Any ideas what to try next?
