Overlock keeps failing
28 Dec 2010
- Intel i7 930
- P6TD Deluxe Motherboard
- ATI 5970
- 6GB ddr3 - 1600Mhz RAM
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21]
Intel(r) SpeedStep(tm) Tech............[Disabled]
BCLK Frequency.........................[181]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1451MHz]
UCLK Frequency.........................[2903MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.27500]
CPU PLL Voltage........................[1.88]
QPI/DRAM Core Voltage..................[1.35]
IOH Voltage............................[1.20]
IOH PCIE Voltage.......................[Auto]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[Auto]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[Auto]
CPU Clock Skew.........................[Auto]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Enabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
When i try to turn on the pc after a while 8 hours or so it'll stay on the starting windows screen and the only way to sort this is to remove the power cable and plug it back in after 10 seconds and it will get past that screen. ive heard this sorts it with the P6TD motherboard when you have a bad overclock.
ive ran 2 x 20 passes of linx and it didnt fail at all and ive also ran prime for 2.5 Hours and it was fine then aswell.
Hi, googled this > How to overclock i7 930 w/ asus p6td and came up with this hope it helps - Remember google is yout friend. :)
i have put my bios template up for you
i'm at 4.2 but you can just lower the bclk to 191, multi of 21, ran @ 15xx (i can't remember exact number its about 1500) and then lower my voltages until you loose stability...Don't forget to set your ram timings!
CPU Ratio Setting......................[21.0]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[200]
PCIE Frequency.........................[101]
DRAM Frequency.........................[DDR3-1603MHz]
UCLK Frequency.........................[3609MHz]
QPI Link Data Rate.....................[7218MT/s]
CPU Voltage............................[1.325]
CPU PLL Voltage........................[1.80]
IOH Voltage............................[1.30]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.40]
ICH PCIE Voltage.......................[1.50]
CPU Differential Amplitude.............[900mV]
CPU Clock Skew.........................[Delay 300ps]
Intel(r) Virtualization Tech...........[Disabled]
