- 30 Apr 2006
- Derby
Monitor = AOC M2870VHE
Card = ASUS Radeon R9 290 (reference)
So I've got this AOC monitor (which is fairly good for what I'm using it for) with a very irritating problem. The image isn't using all the panel, with a gap of around 2mm on the left, right and top and 1mm at the bottom. I know what you're thinking....it's the overscan settings. Well, it's not, as I've already been into those in CCC and set it to 0%. This happens when I'm using a HDMI cable (I've tried 2) and DVI, results are the same on all 3 cables. I've been through the settings on the monitor and can't see any settings that may alleviate the problem. I've also got a 24" BenQ next to it and that doesn't have the same problem through either VGA or DVI.
Any ideas? Cheers
Any ideas? Cheers
