Overtime Tax
5 Feb 2008
Hi all,
Not sure if this is the best place for this but anyway:
I have just had my wage slip and p60 which prompted a quick question.
I earn around 30k a year and do a fair amount of overtime
overtime is paid at £25 per hour
My question is: My overtime is always taxed at exactly 40% so if I do:
20 x 25 = 500 I actually take home 300 extra.
Is that right?
Hi all,
Is that right?
20 (hours) x 25 (£p/h) = £500 (before tax)
£500 x .6 (minus tax percentage) = £300 (after tax)
Is that what you mean?
There is no special rate for OT and if you earn 30k a year then you shouldn't hit the higher tax rate unless you do a serious amount of OT
If anything, the tax code for OT would be the same as a second job, base rate, BR, which is flat 20% across it all. Even if you would earning over the high earners threshold, the OT should still be 20% since that's not your salary.
Though that may be wrong, since that sounds quite fair... :rolleyes:
that was what I was thinking, Who should I go and talk to about it? My accounts team, cab, hmrc?
Check your P60.
What is your Total EARNINGs for the year including overtime and normal salary etc?
Say it's 40k a year.
Take off your personal allowance which should also be shown on your p60 - something like 648L
So 40,000 - 6480 (personal allowance) = 33,520
Your first £37,400 after your personal allowance is taxed at 20%, thereafter the rest is at 40%.
So if you earned £40k as per above you pay tax @ 20% on 33,520 = 6704 which should equal the amount on your p60.
If you've paid more than that is tax - contact HMRC and ask to reclaim the tax.
http://listentotaxman.com/
I just used booyaka's example and it comes out perfectly to what I have paid so I guess its right.
I guess my student loan might be don't swear with my take home more than I thought.
