theres are 2 lights on the front panel of a p180, what are they both for?
theres one blue one at the bottom which ive seen flashing away, but ive never seen the top light flash...whats that one for? maybe i plugged my connectors up wrong
The two inside the case front (not visible when closed) are HD I & HD II. The small led just above the firewire is POWER. Most motherboards don't have led's or HDI and HD II this is why you will not see them both light up.
