17 Oct 2006 at 11:49 #1 gooner_47 gooner_47 Associate Joined 9 Mar 2005 Posts 162 Plans are: P180 Gigabyte DS4 Seasonic S12 500W Will there be any issues with all the necessary cables from the PSU reaching where they need to on the motherboard?
17 Oct 2006 at 12:26 #2 33L 33L Associate Joined 25 Sep 2006 Posts 1,989 Location Windy Sheffield im running a gigabyte board with an antec psu and if the location of the atx power connecter is the same (top right corner) then you should be fine
17 Oct 2006 at 15:14 #3 sativa1874 sativa1874 Associate Joined 29 Jul 2006 Posts 149 Location Edinburgh I have this case with an ennermax liberty 500w and theres no problems.
17 Oct 2006 at 15:31 #4 gt_junkie gt_junkie Soldato Joined 20 Mar 2006 Posts 8,107 Location The Lakes I'm running a P180, Tagan 2force 580 and a sapphire pure advantage rd580. Mobo needs sooooo many cable connections but it all seems to cope ok! My 2x12v feed for the CPU is top left of the board and the cabling just reaches! If you have any problems it's fairly easy to source extension cables to help! Sure your set up will be fine! Nice case by the way! Bit cramped, but cools real well if you lay everything out right! gt
18 Oct 2006 at 08:56 #6 33L 33L Associate Joined 25 Sep 2006 Posts 1,989 Location Windy Sheffield never a problem bud!
18 Oct 2006 at 15:08 #7 gt_junkie gt_junkie Soldato Joined 20 Mar 2006 Posts 8,107 Location The Lakes No probs! gt
