P180 Total Idiot Question
7 Feb 2007
Ok I give up, how in gods name am I supposed to fit the slide in brackets for the Optical drives, if I fit them flush as such, drive sticks out miles, tried many combo's....HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You don't fit them flush, you fit them so they stick out further than the drive. Once they are fitted, slide the drive into the case and you will find everything sits flush ;)
