p180 water, advice needed
26 Nov 2008
Leeds
As in the title i am concidering water cooling but the case i have is really kind of restricting.
I am not sure whether 2 120mm's is enough or if it would be worth attempting to mod the top of the case to fit a 240mm and have a 120mm at the front.
anyway if 2 120mm's would do i am looking at something like this.
again any hep or advice apreciated.
edit:
yes i am 2 barbs short and i just realised i dont need one of the 90degree barbs because i can just put a normal one on the top of the block as an inlet from the cpu cant i.
